Profibus
Caveman
May 2002
Cadiz, Kentucky
212
We are having problems backing up our profibus Scanner
to a spare/backup scanner.
PLC must be in Program mode or
Not in rack.
To upload from card, open SST software.
On left plane, select Master from info on card.
Click Connect radio button.
Answer NO to upload.
To download to card, Open file needed to
Be loaded to card. Then click Connect
Radio button. Then click
Load Configuration radio button.
Answer YES
These instructions Don't work.
The card is SST-PFB-SLC Ver 2
The Software is SST Profibus Configuration Ver 3.8
This the second attempt to get this done and we still dont't
know what we are doing wrong.
Please help.
Going from memory here. In your sst configuration software do an export of your file to a file format for hyperterminal. Put the plc in program mode. Hook up to the Profibus card and open hyperterminal. I think it is * to get the sst card in configuration mode. Seems like there was a clitch here and you had to hit enter a couple of times after * to get it to take. Next download your exported file from the sst software. All of these steps are in the manual.
Sorry I waited so long to reply but I'm also waiting from
the person that did our training to confirm or come up with
an exact procedure.
The machines are running and we don't want jeopardize that.
Looks like the key is to get the card in configuration mode first,
then do all the transfering.
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
197
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
93
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
114
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
328
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
326
