Profibus
randy
Supporting Member
Apr 2002
158
Had a strange event happen to our Profibus network on a robot welding cell. On six of the nodes, 4 being just inputs and 2 being Festo valve blocks, we lose the functionality of these nodes. We did not get a bus fault on the Siemens S-7 314-C-DP2. When I opened the hardware configuration through Simatic Manager and double clicked on the nodes I got a message “Device configured but deactivate”. I tried to connect to the Profibus directly with Simatic Manager, but was unable to see the nodes. After about 8 hours on the phone with Siemens tech support and troubleshoot all cables and connections I decide to select a different part number through the HMI. I notice that the fault indicators on the individual nodes were all off. The system was back up and running. I then selected the same part I had in before and still all was running fine.
I’m just still puzzled on what happened; maybe I could get some feedback. Also, what is the best Profibus troubleshooting tools?
Randy
What message was in the CPU diagnostic buffer?
Could there be logic disabling the nodes for a particular product type? SFC 12 ?
I looked to see if SFC 12 was being used, but it was not. But there was a message in regards to OB86.
Sorry I did not log it down and it's been a few day since we had this issue. Thanks for responsing to my posting.
Next time I will record what the diagnostic buffer message display's.
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
203
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
99
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
120
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
329
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
329
