Profibus
joblack33
Aug 2002
Hi!
How can I setup a profibus system using SIEMENS S7-200 PLCs?
Can I use a S7-200 as Master?! and connect a AS-Interface to this Profibus system?!
Bye!
Amir Ganjeii
The S7-200 can only be a profibus slave using the
EM-277 module. It can be an ASI master. Look in the catalog for the number on that module.
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
196
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
92
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
113
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
327
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
322
