Proficy ME - comparing two offline projects (Rx3i PLC)
cstca
Mar 2005
Toronto
33
Question for PLC programmers with GE experience: what is the best way to compare two offline projects developed for Rx3i PLC?
We used a tool called CE Compare (not very nice but was doing the job), unfortunately this software is limited to 90-30 and 90-70 PLC. I called GE Support and they confirmed there is no tool developed in Proficy ME and they are not planning to develop such a tool. There is a way to compare the online program with the offline project, but most of the time I don't have access to a PLC and download my project just to do a comparison. I'm thinking to use Excel for this but I'm wondering if there are better ways to do it.
Thanks.
CoS
You could print the programs to PDF files so you could open them side by side and do a very coarse compare. I use PDF redirect as a PDF printer.
Not much better but maybe a little faster depending on the 'layout' of your Project.
In PME Right-Click "Program Blocks" and Export all Blocks to an empty Folder for each Project.
That will give you one 'xml' file for each Block.
Use your favorite file comparison utility to locate which Blocks are different and by looking at the xml file you can get a close indication of which rung(s) are different.
http://www.techsupportalert.com/best-free-file-comparison-utility.htm#Quick_Selection_Guide
I like Kdiff3. YMMV
Definitely not the best way, but finally an improvement from GE.
If you have PME 8.0, you can run multiple instances. Open two instances and put them on different monitors. Then compare rung by agonizing rung.
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
53
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
109
Hi I am wondering if the RXI-042 PLC model (below PN) is programable via Proficy Machine Endition, if so, what is the firmware version needed for...
105
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
75
I am trying to download a program with usb to serial cable in rx3i IC695CPE305 while logic and configuration is equal but when i start downloading...
50
