Proficy
Open "New Project"
Here you will select what type of device.
Ex:9070, 9030 etc
Right click Target1
Import: I selected "logicmaster folder"
There are other choices here.
You will be warned that you are importing over an existing folder (the temporary one you just created).
when completed you will get a report of the status of your converted program.
Warnings are expected, errors will not allow you to run.
Proficy likes to handle all register entries as "arrays" and will name them that way. This may cause a problem with your current naming convention, but you can configure proficy to ignore them. There is extensive help available in the software.
You may have to "flash" your processor to be compatible with Proficy, but the flash info is available and can be found by doing a google search.
There's more to it than this, but this will get you started.
Good luck!
Most of it works automagically.
I've converted Versamax, 9030, and 9070 into Proficy with no problems whatsoever.
Also the quickpanels convert just as easily.
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
70
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
120
Hi I am wondering if the RXI-042 PLC model (below PN) is programable via Proficy Machine Endition, if so, what is the firmware version needed for...
107
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
77
I am trying to download a program with usb to serial cable in rx3i IC695CPE305 while logic and configuration is equal but when i start downloading...
53
