Profinet Comms to PC
Revver
Apr 2011
Northampton
22
Hi
Can anyone help with this standard problem.
I have a 315 2PN/DP CPU, the Profinet is to be connected to a PC which will send the CPU a value representing a product size. I cannot see where in the S7 software i set up the data area where the PC will write the data to.
I don't know what card is in the PC as this is coming from a third party company.
I have done this previously with DP PLC - PLC but this is the first time i've been requested to link PN to a PC for data.
Hoping you can help.
"Profinet" is an Ethernet protocol similar to "Ethernet IP" or "Modbus TCP/IP". They all use the lower levels of Ethernet equally but the top layers are as different as speaking "Farsi" and "Japanese". You will need software that speaks "Profinet" on the PC.
OPC attempts to be a "universal" translator.
Hi all, I am trying to get my head round Profinet comms. I need to communicate with a Robot that has a profinet card fitted. The card is set to...
3,142
Any insight greatly appreciated. I need to communicate to a slave device (non Siemens) with a siemens plc with profinet and profibus DP-V1 for...
3,778
I am looking to monitor Profinet communications to some drives from a Siemens S7 1200 plc. By monitoring I mean detection of the drives on the bus...
4,167
I'm trying to communicate between an S7-319 and a Sick CLV650 Profinet scanner. The scanner is setup and scanning ok and gets an IP from the PLC...
1,553
147
