CLV650 Profinet comms to S7-300
IanRobo75
Jan 2012
Christchurch
I'm trying to communicate between an S7-319 and a Sick CLV650 Profinet scanner. The scanner is setup and scanning ok and gets an IP from the PLC so it seems that the PLC/Scanner comms is ok. However, the 64bytes in and out that we've configured in the S7 hardware (using the latest GSDML file) are showing with a red line though, since they can't be seen.
Is there anyone out there using this scanner and an S7 that can help with the configuration?
155
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
388
I want to establish a Profinet network in my production plant to connect multiple devices, including a PLC, HMI, and multiple Profinet-based...
19
695
Hi, I have a customer with a S7300 from around 2013 which they link to approx 25 inverters, 3 DP to DP converters and 5 IM153 remote I/O units...
325
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,885
