Profinet I/O VLAN
gcm800
Nov 2018
Nuevo Leon
Is possible to manage several Profinet RT I/O in different VLANs in one switch?
The idea is using a ring topology switches in order to connect the I/O on the field, but these I/O belongs to different PLC, we want that the I/O and it´s PLC in different subnetworks but we do not want to have more than one ring, we want to use one switch in each location in order to connect the I/O from different networks in one switch with VLANS.
In general, yes: multiple PN networks can be split into different VLANs in the switch.
However, do be careful how you set up the VLANs in each switch. By default Profinet IO traffic is sent with high priority (6 out of 7). As you add it to the VLAN, make sure it keeps the priority. Also note that when you remove the VLAN, the priority then is removed as well.
This doesn't matter often, but I've seen it take systems down.
Strictly speaking, the answer depends on the switch you're using, but I can't see why not. I've seen switches that allow you to configure the priority of a VLAN, but never one that limited your options based on what other vlans are set to.
My experience with VLANs in the past has been that everything on the VLAN inside of the corresponding subnet should be able to speak to one...
6,030
197
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
427
I want to establish a Profinet network in my production plant to connect multiple devices, including a PLC, HMI, and multiple Profinet-based...
19
729
Hi, I have a customer with a S7300 from around 2013 which they link to approx 25 inverters, 3 DP to DP converters and 5 IM153 remote I/O units...
334
