Profinet protocol supported industrial devices
mbreddy
Nov 2014
bangalore
22
We need to interface an industrial device (which supports profinet protocol) to PLC.for Ex sensors or any small device. Unable to find myself.
Thanks,
mbr
Profinet is an ethernet based, realtime, deterministic protocol (like Powerlink and EtherCat), it may not be supported by many low end PLCs. If you don't actually need the speed and precision of Profinet, you can use a gateway device to convert to Modbus or something similar that would be supported by more PLCs.
Keep in mind, ProfiNet and ProfiBus are completely different things.
Thanks for the response.I have Allenbradley 1766L32BXB PLC.We need to find and interface devices which supports different protocols like(profibus,profinet,modbus..etc).
To connect a ProfiNet device to an A-B controller is going to cost more than the controller itself, by a lot.
I would start with HMS Anybus and their various gateway products.
Siemens S7-1200 as Gateway
Dear mbreddy, If your AB support Modbus TCP or RTU. You can use a cheap S7-1200 (i.e. 1211) as a network gateway, you may have to do a little of programming, but it's easy. with it you can connect to PROFINET networks as master (io controller) or slave (io device), it can also work as PROFIBUS master or slave (adding communications card). Best regards, kelkoon
I suggest you switch to a PLC/PAC that supports Profinet directly either GEIP or Siemens would be my first and second choice. In that order.
what is the field device with Profinet that is so special that you can't substitute another field device with which you can communicate in some other fashion?
DCP – Discovery and Configuration Protocol packets are well documented, except one field "Xid". This is a 32 bit value, it looks like it has...
1,490
Hi, Does anyone know any HMI or protocol converter that can connect to a Profinet network/devices (Siemens SITRAS MDC protection Relays)? Red...
1,865
205
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
434
I want to establish a Profinet network in my production plant to connect multiple devices, including a PLC, HMI, and multiple Profinet-based...
19
738
