PeterW
S7Guy said:I like to add comments liberably as well, but not within the comment header of the network
I do similar, sometimes it can be just a single line identifying what the next group of instructions are about.
// If the overload is OK when required to Run then start the drive //
-motorA
-motorA O/L
---| |-------|/|-------( ) -Run_Motor
// While "Call for Run Motor-A" is ON, if "Motor-A O/L is Tripped" is OFF, then...
turn ON "Run Motor-A Drive" //
Call Motor-A
for Run O/L is
Motor-A Tripped
---| |-------|/|-------( ) Run Motor-A Drive
A Call_for_Run_Motor_A
AN Motor_A_O/L_is_Tripped
= Run_Motor_Drive_A
// While the call to run the motor signal is ON... if the motor overload tripped
signal is OFF, then... turn ON the output to run the drive for that motor. //
Device E-Stop
Cause-A Faulted is OK
---| |---+---|/|------| |----( ) Turn ON Device
Cause-B |
Cause-C |
Cause-D |
If you want the book... yer gonna have to pay for it! Fair is fair... no?
Terry Woods said:...but I am not pleased, not pleased at all, with the signal names (especially the signal names), nor the comments.
Terry Woods said:A -motorA // If the overload is OK when required to Run
AN -motorA_O/L
= -Run_Motor //Then start the drive
Doesn't the above code (and comment) look like this in Ladder...
-motorA
-motorA O/L
If there is data present on the end position the type of data is determined:
- Reservation/empty window code or (UFO)PIC
- In case of (UFO)PIC: Induct bit or not
If the data is a reservation/empty window code or a (UFO)PIC with induct bit
(NO physical product expected), the one-shot data_sync is directly SET, the
data is copied to the FIF downstream and the entry is deleted from tracking.
If the data is a (UFO)PIC without induct bit (physical product expected) the
following handling is executed:
- If the product is at the handover position and being handed over
(M_SI_Hand_Over), the one-shot data_sync is SET, the data is copied to the
- If the product is at the handover position (product offset >= handover
offset) and NOT being handed over (eg in a die-back situation) nothing
happens.
- If there is NO product at the handover position (NOT M_SI_Hand_Over and
product offset < handover offset) the entry is deleted from tracking
(invalid entry).
NOTICE: The detection of data at the end of the conveyor and the detection of a
product at the handover position comes exactly at the same moment!
OPN #i_DB_Track // Open tracking DB
L DBNO
T #t_DB_Num_Track // Determine tracking block DB number
SET // RESET one-shot handover data
R "M_FD_Data_Sync"
// Check if entries are used in the tracking DB
L DBW 0
L 0
>I
JCN HA99
// Determine pointer to last used entry
L DBW 0 // Number of entries used in tracking DB
SLW 5 // Shift bytes to make pointer to last entry
L P#2.0 // 6 (Header lenght) - 4 (record lenght) = offset
+D // Add offset to jump over tracking DB header
LAR1
// Detect data at end position
L DBW [AR1,P#0.0] // IF position of last entry >= position end
L #t_Position_End
>=I
JCN HA99
// Determine data type at end position: (UFO)PIC or Res/E
// Determine if the induct bit is set in case of (UFO)PIC
SET // Reset data type bits
R #t_Data_Is_PIC
R #t_Data_Is_Induct_Bit
L DBW [AR1,P#2.0] // Copy data at end position to temp
T #s_Data
L 0 // IF found data is a (UFO)PIC code
>I
JCN HA20
S #t_Data_Is_PIC // SET temp Data_Is_PIC
TAR1 // Copy AR1 to temp t_Memory_AR1
T #t_Memory_AR1
CALL "FC_Read_Bool_Record" // IF induct bit is set (no physical product expected)
i_Record_Number:=#s_Data
i_P_BOOL_Record:="DB_UDT_PIC_Record".Status.Induct_Bit
i_DB_Number :="DB_PIC_List"
o_BOOL :=#t_Data_Is_Induct_Bit // SET temp Data_Is_Induct_Bit
L #t_Memory_AR1 // Copy temp t_Memory_AR1 to AR1
LAR1
HA20: ON #t_Data_Is_PIC // IF data is Res/E
O #t_Data_Is_Induct_Bit // OR data is Induct (UFO)PIC
O(
A #t_Data_Is_PIC // OR data is (UFO)PIC
AN #t_Data_Is_Induct_Bit
A "M_SI_Hand_Over" // AND at handover position + being handed over
JC HA50 // THEN jump to set data sync
L "MW_SI_Product_Offset" // ELSE IF NO product on Handover position
L "MW_SI_Handover_Offset" // (Product offset < Handover offset)
<I
JCN HA99
T #t_Memory_AR1
CALL "FC_Log_Event_Track" // AND Report event PIC data lost due to wrong position
i_Event_ID :="DB_Event".Tracking.PIC_Lost_Wrong_Position
i_Event_Data:=#s_Data
i_AreaID :="MW_SI_AreaID"
i_ZoneID :="MW_SI_ZoneID"
i_SectionID :="MW_SI_SectionID"
L #t_Memory_AR1 // Copy back temp t_Memory_AR1 to AR1
LAR1
JU HA51 // AND jump to remove (UFO)PIC from tracking
// Set one-shot data sync + copy data to FIF Downstream
HA50: S "M_FD_Data_Sync" // SET one-shot handover data
L DBW [AR1,P#2.0] // AND copy data last entry to FIF Downstream
T "MW_FD_PIC"
HA51: L DBW [AR1,P#0.0] // Copy position to temp
T #t_Pos_Data_Delete
CALL "FC_Write_Track_Unc" // AND clear entry from tracking
i_DB_Num_Track :=#t_DB_Num_Track
i_Position_Write:=#t_Pos_Data_Delete
i_Data :=0
HA99: NOP 0
The sample you disected was a very simplified example, it is normal in STL to code as much code in a single network that ladder code take 10, 20 or more networks to achieve.
rsdoran said:This part has me confused, I have not heard of this, got an example of STL in one "network" that would translate to 20 rungs of ladder?
Cause Interlock1 Interlock2 Output
Cause Interlock1 HelpReason1
Cause Interlock2 HelpReason2
