Program to Run mode Question
gizmo
Aug 2002
95
1756-L55 ControlLogix5555 Controller
RSL5K v.12
I've got a simple PIDE Block with an input reference to the PV and an output reference from the CV.
When I turn the key from Run to Program then back in Run Mode, the CV of the PIDE block goes to "0%". I beleive I've got other PIDE blocks that their CV's don't go to "0%".
Note: I'm not downloading to the controller, just turning the key.
Any ideas on what settings/parameters that may cause the above?
Thanks!!
Follow up
Control Action = True = PV-SP.
I'm not real sure how control action would cause the controller to put out CV=0% when swithed to Program mode and back Run.
What do you want or expect the controller to do if your PV input signal burns out or goes open?
Some processes it will go upscale some it will go downscale, it all depends on what you are controlling.
This might be what you are seeing.
I had bought a used PLC before but I had to return it. Once in a while its run mode shut off momentarily. I had the PLC on my desk. (No I/Os...
22
5,380
Hi, I am curious to know what will happen to a Running 1756 ControlLogix L73 controller if the keyswitch is changed from Remote Run to Program...
1,614
Hello I am working in a project where I use a processor 1756-L63, two ethernet cards 1756-ENBT/A to have a redundancy network with the...
4,079
Hello everyone!!, I may be asking a newbie question, but I want to be sure of that. Can I run a PLC program directly from the SD card? I mean, I...
191
Dear Everyone I work with PLC GE-Fanuc. But I don't know that "PLC GE-Fanuc (Series 90-30 and VersaMax) can Online Edit Programming while...
3,053
