programing advice
Tbuck24
Aug 2010
Altoona
I am Not and experienced programmer but I am getting a machine running again at my facility. one line of code got erased in my program I am reinserting it and am getting a step overflow error can anyone help
program looks like
117 out t 24
k 6
after the k6 I hit go and I get step overflow . :oops:
You'll get better quality answers by asking better quality questions. It would be helpful if you identified the brand and model PLC and the programming device or software you're using to program it.
At first glance it looks like you might be entering an incomplete rung. I suspect the "117" is an address that needs to be associated with a contact instruction so that if the 117 contact instruction evaluates true the timer T24 will start timing. Of course, there may be other missing logic before the "117".
I will take a guess on the limited info avaliable.
I suspect the timer OUT T4 K6 is within an STL state
(it's the only instance in mitsi where you can have just a timer on a line)
The step overflow means that there are too many steps on that STL branch (there is a limit)
You might need to go to a fresh new line to insert the timer.
Just a guess
I just got offered a job as a plc/robot programer for a company building machine. The issue is i am a very good plc programer but never have I...
19
4,336
Hello, I have Guard PLC 1600 by Rockwell Automation (it has been obsolete by them but still in the market and works fine). I need know if this...
1,241
I got DL06 AutomationDirect PLC to program with DirectSOFT6. It is a simple machine (40 in and 20 out, all digital), few valves, a simple conveyor...
23
6,955
Please suggest me programing cable for omron plc sysmac model no. Cpm2a
1,140
hi all, I am a PLC beginner.trying to learn how to program on my own at home. I am about to purchase a training kit online and just needed some...
17
5,210
