Programmable Logic Control Applications
Apr 2006
Lincoln, Nebraska
I am a student in a PLC class at a local community college. I am trying to write a paper on the practical uses of PLC's. Does anyone have some very basic information about PLC applications. For example, how are they used in common products? Your help would be greatly appreciated.
Thanks!
PLCs are not used in common products.
They are used to control the machines that make common products.
Take for example one of the best and most useful products in the world - Beer.
Think of all the steps needed to get the beer from the brewing tank and into the bottles. This requires a lot of machinery to do, and is generally fairly well automated. Now what controls the machinery? What tells the conveyors to start and stop? What tells the valves to open and close? Where is the brain in this process?
I dont think there is a product out there that does not have PLC's involved...I have instaled PLC's at a public pool's hot tub to control the jets and i use them in water bottoling plants and milk plants..also meat plants and pckaging plants...hell name an application and i am sure someone here has worked on one...!!!
PLCs are also extensively used in the agriculture industry. Cotton gins use them extensively, lots of the major farm machinery (tractors, etc) use them, mills use them... Really you will find a PLC in almost any industrial process.
If you want documentation of how PLCs are used in a few machines read a couple of our service manuals (http://support.samjackson.com) and you should get a good idea of what a simple PLC can (and does) do.
Sliver said:
I'll bet they even use PLCs to manufacture PLCs!
You won't be able to! Bookmakers don't take on bets unless they're sure they can win. I bet you will only get a 0 to 1 bet on this at most. But hey, we're talking about digital equipment, ain't we?
Kind regards,
I suggest that you simply browse the threads of this forum. The uses of PLCs are so diverse and there are hundreds of threads on hundreds of applications right here.
Funny you should mention that!!
I do work at a small manufacturing plant and these huys manufacture a certain PLC module for GE...Now i had to do an audit on there equiptment..(Not CSA certified) and 99% of there equiptment used PLC's...Not 1 of them was a GE!! I shook my head at the guy and told him he was biting the hand that fed him...But to confirm what you said..Yep..they use PLC's to build Plc's...but not always by the same manufacture!!!
D
If i talk about PLC (Programmable logic control ) this is for automatic control machine if you have question about PLC you can put question in...
21
Can someone recommend me a compact device to control logic on/off beacon according to signal from a PIR ? Some RTU maybe. I am newbie in...
2,194
I'm looking at a online textbook called Programmable Logic controllers by Frank D.Petruzella. I would like some opinions on this book. I know I...
7,658
Hi Iam writing a report on I/O field devices and communication links field communications and need some help. Also types of networking...
1,598
Hi everyone, I know this is an old one but we have a d100 in our wrapper , it just stopped working. When the inputs are pressed the corresponding...
239
