Programming a Mitsubishi HMI
Jul 2010
Richford, NY
Hello all again,
I have a machine with a FX-48MT PLC with a HMI interface very similar to the machine in my last post. I do not know the exact model of the HMI. This HMI has a cracked display and only part of it is readable. We found a new HMI online some where and bought it.
I need to know what software and hardware (hopefully it is just a cable) is necessary to extract the program from the old HMI and load it into the new HMI.
Thank ou for your help.
More information
Sorry, in my ignorance I assumed that only a Mitsubishi HMI would work with the Mitsubishi PLC. I did not think that model would be that important because I was thinking all models that would connect would have thew same software and connection.
The HMI is a Mitsubishi MTA-100. The only connection that can be see without taking it apart is a DB25. The lable says it is 5 VDC so I am guessing that it gets it from the DB25. Is is some form of serial?
Thank you,
Well I found a way around the problem. Originally I needed to set-up a Mitsubishi MTA-100 to replace one with a broken LDC. I just took the LCD from the good one and put it back in place of the broke one.
Now I have a new MTA-100 HMI with no display.
Hello guys I have two "silly" questions First, I want to monitor the current temperature of the heater through an HMI,please can someone tell how...
3,345
I'm been deciphering a program for a press here. I've gotten most of it deciphered using the manual to understand the instructions (first mitsu...
345
In this sample programming, what does U4 mean? Any assistance would be greatly appreciated.
298
Hi can you help, have a book stitching machine with collates pages in 8 stages. I have installed a camera system that will give an input to...
24
1,989
Hi, My next project is an entirely different platform, its Mitsubishi. I'm using FX Series PLC With 40 Di & 40 DO FX5 80MT and 7" Touch Screen...
3,827
