dwoodlock
What you said as far as triggering the BSL makes way more sense to me when you applied it to my actual program and I thank you for taking the time to look at it.
I am using the bits in the second word of the 32 bit allotment, but I wrote that portion in a seperate ladder file. I can show you that also If you like.
I appreciate your advice, I guess my issue is more (like you said) I am thinking about it the wrong way. I guess I need to figure out a way to make the camera result or evaluation happen before the shift takes place. so that when the shift takes place my good or bad result is already done. (this was the benefit to using the camera evaluation completed inputs, I was'nt sure what a better way would be)
I am now in the process of adding an encoder to the machine to help attain a more uniform movement reference.
thanks again.
thanks again.
