Programming DL05 module F0-4AD2DA-1 using Directsoft5
Bowen
Mar 2013
Belize
I have a DL05 PLC with a module (F0-4AD2DA-1). I have a project that reguire a analog input of 0 to 200 degrees Celsius (Analog Input mA), which controls a Pneumatic valve (Analog Output mA) to control a set point at 140 degrees Celsius. I am using Directsoft5 software but i am new to this. Does anyone out there help me with the Programming-Logic Diagram for this project.. it would be highly appreciated. Thanks
Hello
Also try chapter 8 of the DL05 users manual it gives a very good description of P-I-D loops. Right off the bat in chapter 8 there is a simular example. Also visit there web site below and open the technical note under General called PID Tutorial. This will also help to get started. Also I remember seeing a video on utube on PLC Direct P-I-D Loops.
http://support.automationdirect.com/technotes.html#plcgeneral
Have A Good Day
Tom
Hi, I am trying to set up a plc. I've never done any programming with ladder logic previously. I'm trying to set up a a program to turn a device...
223
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
135
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
942
I need to pull the program off of an old 90-30 so I can convert it to Allen Bradley. This is my first time messing with GE and I don't have the...
93
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
492
