Programming FX PLCs at 19200 bps
quarantasei
Oct 2009
bangalore
Hello,
I am able to program Mitsubishi FX1N plc using GX-IEC developer with the following default COM params : 9600 bps,Even Parity,7 data bits, 1 stop bits.
But is it possible to program with a different setting like 19200 bps or odd parity? I got info that the programming port of FX1N has fixed settings. So is it possible to use a different setting through a BD like the FX1N-232BD? Or are there any other interfaces available for doing this?
Thanks!
The max baud on FX1N is 19200. You merely set it under online - transfer settings. not sure if you know but you can make a cable to talk to fx series excl fx3u as follows.
Also if you want serial numbers for mitsubishi software all you have to do is open the following file that comes with the installation of any melsec software. Open it under wordpad and scroll to you find numbers. Just as easy as 123. also here is a program to crack the passwords on mitsubishi plc's.
I would like to learn PLC programming. There isn't really a specific reason. Automation and electronics thrill me I suppose. I have all kinds of...
3,959
hello to all!!!! my HMI OP320-A display is in chinese which is already programmed,i contacted with the machine mnufactererer they...
2,471
Good Evening, All, Let me first apologize for this becoming something of a rant. I have a sort of a style-related question running around in my...
18
9,189
Hi How are you all doing. Im very confused about a program that im trying to migrate from an old version plc to a new version (tsx p572623) im...
3,034
I was working with a person from Europe and they used Siemens PLCs. I had never used Siemens before, and he mentioned that Siemens had different...
8,695
