Programming Variable Speed Drive using Rs Logix 500
Joe Frey
Jul 2014
P-L
25
Hi everyone, I am an automation Student and I'm new to PLC programming with Allen Bradley Rs Logix 500.
I have to upgrade an actual automated cooling wine fermentation process by using new a new PLC, HMI and implement the use of Variable speed drive.
I have [FONT=&quot](2) x 3Φ centrifugal KSB water pumps of 3kW output power each[/FONT]
Actual PLC : SLC 500 (1747-L532)
Proposed PLC : MicroLogix 1500 (1764-28BXB)
Proposed VSD : (2) x Vacon 0100-3L-0008-5-Flow
I would like to know if i will use analog output modules for the VSD ( Will the VSD use them)? I am planning to use two seperate VSD for each pump.
How analogue outputs are programmed in Rs logix 500 ( The Instruction blocks to be used etc)
Anyone can give me a guideline, a tutorial that can help me, or a proposition on how i can use the VSD for the 2 pumps?
Thanks in advance!
Hi everyone, I am an automation Student and I'm new to PLC programming with Allen Bradley Rs Logix 500. I have to upgrade an actual automated...
2,540
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
117
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
903
I need to pull the program off of an old 90-30 so I can convert it to Allen Bradley. This is my first time messing with GE and I don't have the...
85
