Prolem with uploading to Magelis
kallileo
Jun 2008
Thessaloniki, Macedonia, Hellas
353
I'm trying to upload an application from Vijeo Designer Lite to a XBT-N200 but I'm getting a message saying "No terminal connected". I'm using z925 cable and TSXCUSB485 usb converter.
Few weeks ago I had uploaded the same application to an identical XBT-N200 without any problems using the same PC but now just can't get it work...and I have tried 3 different PCs.
Check the orientation of the Z925 cable. The terminal should be saying 'waiting for transfer' with the correct end plugged in to it.
Pinout on magelis RJ45 connector is probably different than on earlier magelis screen, what you have used. (Schneider changed magelis RJ45 pinout last year, so you will need special adapter cable for downloading. This depends of when your screen is manufactured)
Try downloading with XBT-ZN999 adapter cable between z925 cable and usb converter.
(if there is no schneider or telemecanique logo on screen, you need zn999 adapter cable.
If screen has schneider or telemecanique logo, then you don't need adapter cable.)
Both screens were bought 1 month ago. Both have Schneider logo on them.
I believe something is wrong with Unitelway drivers.
I have installed 1.3 version of Vijeo Designer Lite that has 1.1v Unitelway driver.
I re-iterate this statement, check this first before the drivers. It is hard to believe that the same drivers that worked, not do not work on 3x different PC's.
Are you using the same USB port? Some USB ports don't have the power (W) needed to power the 5V XBT. Try using another USB port.
Hi when i try to create the processor the program gives me an error, i upload the images i hope you can help me internal error. Rslinx Service is...
3,583
Hi, looks like I can't datalog floating point numbers using a micrologix cpu and logix500. I CAN use Long and Int. My problem, I need to record...
3,292
I am trying to read some tags using Rslinx server thru DH+ in microsoft excel. For this I have configured a topic for that particular PLC(AB...
10,499
How can I access the web page that allows me to see and upload the pcl or translation file into my Pl1000E? My Pl1000E doesn’t have an ethernet...
135
Hi guys, I have had some issues with uploading a program from a Micro 850 PLC. This is the first time connecting so I don’t have a file on my...
302
