Proportional hydraulic valve : performance limit
aand74
Dec 2005
Deinze
131
We have a proportional valve where we suspect that we may be at the performance limit.
With the performance limit, I mean what I see in a curve of flow in function of valve pressure differential. So, big pressure difference at the valve combined with high flow.
What are typical results when a proportional valve is at this performance limit?
the proportional valve is limiting the rate of change of position of the actuator. The pressure drop is across the valve instead of at the actuator.
Tell the production people they just won't be able to leave early on Fridays. J/K...kinda
Seriously though, if this is on a machine that has been "ok" so far. When you start to question if you are at a critical mass with component limits, typically something else a lot simpler is wrong.
Not always, but typically.
Here's an easy check.
1) Record nominal flow rate of pump
2) Record volume characteristics of actuator. Cylinder area, etc.
3) Evaluate what the speed of the actuator SHOULD be according to your findings.
4) Measure actual speed of actuator
If substantial difference, measure actual pump flow rate and case drain too if you have access to it. High flow rate on case drain is the smoking gun for a toe up pump.
What brand servo valve are you using and what flavor pumps and actuators?
Has anyone on hear ever heard of controlling a proportional hydraulic valve directly from a PLC with a PWM output and SSR, instead of using an...
19
5,363
Hello! I have a signal converter, reference PEM - 020 - G24 , which converts a signal of 0-10 V to a current signal that goes to a proportional...
1,881
In the attached picture, you can see a hydraulic schematic of our installation with a proportional valve (Atos) with integrated force control...
26
11,366
Hi, I am an inventor looking for a way to automate a block-making press I made out of a log splitter. It makes blocks for building homes from...
7,226
Hello guys, The processor is a SLC 5/04 using RSlogix 500. Have a question about a proportional valve on our hydraulic system on one of our...
3,616
