my project
It is necessary to use air-chamber to heat or cool offices.
What we want is to achieve a certain temperature with unpolluted air and the maximum energy savings. We inflict desired temperature depending on weather conditions.
There are three basic parameters to set up which lead and manage the entire system. These are the inlet and outlet temperatures and air pollution.
Based on the input temperature we are dosing three-way valve on the hot water exchanger cooling exchanger. Depending on the season, we choose which exchanger is needed. Pump is on at 5% openness of the three-way valve. The input temperature is the leading parameter in this and it must be the setpoint which must be ensured. I need here a PID regulation. (don`t know how to set it up).
With the VOC sensor, which measures air pollution, we manage input and output and circulating dumper. If the air quality is in normal range then the circulating dumper is fully opened (located in the middle of the functional diagram). If the value exceeds the allowable pollution criteria the simultaneously are opening input and output damper. Circulating damper is being shut down as the output damper is being opened. Their sum must be 100%.
The condition for the ignition of fan are the outlet and room temperature.
Based on them we also turn on the bypas (Fresh Air / recovery). This applies only during cooling and when the outside temperature is more suitable than the room (exit) temperature.
All other signals are digital and can have value 0 or 1 (eg, fan on-off, a dirty filter).
What I`ve done so far are the digital signals, VOC and bypas.
The thing I dont know is the PID regulation. If anyone find this interesting please help.
