Prosoft 3150-EMR Manual
Give them a call, they have excellent support. They just might have one laying around
in that dusty room in the back.
It is on an old machine of a customer of mine's. I got the part number off of the electrical drawings. I do get quite a few hits on google, so it does seem that the 3150-EMR did exist as well. Although the manual you linked is extrememly similar to what I saw today. I wonder what difference there might be if any.
Are these things just BASIC modules with modified firmware?
I believe they are just modifoed bascic modules. The FX drives could receive/send ascii strings to communicate;
"DS1=1500" would set INDEX #1 distance to a value of 1500 (all integer) The resolution is set in the drive configuration.
You can find a manual on Emerson's site for "FX serial commands"
The AB end was alot of BTW/BTR commands and copies (I don't program AB's)
Yeah, I'm pretty savvy on the Emerson side of it. I had just never seen this particular Prosoft card before. I have used the BASIC modules. The customer purchased an EP to replace the old FX/PCM but obviously the EP doesn't support ASCII or RS232. So I need to understand what data the Prosoft module was sending back and forth so that I can get it done in some other fashion.
I have PLC5/30 system having modbus communication with VMS and DCS. i Have the logic backup alone. Anybody please tell how to find the modbus...
1,231
Hello Guys. I have a Prosoft 3150-MCM connected to a woodward MFR-15. I got the MODBUS address from the supplier of woodward. The faults I...
4,741
Please clarify on what is happening on the following code. This code is writing data to the MCM module of a SLC 5/02. The data written on the MCM...
7,555
Based on the print screen attached or the default sample program given by prosoft 3150-MCM module, does anyone knows where is the communication...
7,301
Hi, We have an application that has a device that goes through a reboot (appears un-graceful) What then happens is the MVI module appears to hang...
75
