ProSoft BacNet PS-QS-1x10-0780
celichi
Apr 2008
Greater Toronto Area
415
Good Morning,
Has anyone used the Ethernet/ip to Bacnet IP Gateway?
Do both Ethernet/IP and Bacnet/IP exist on the same LAN?
Thank you,
Paul
Hello all. I have a project that requires the use of BACnet over RS485. I am looking for something low-cost that I can connect that will talk...
1,822
Good Morning from the "Waist Deep in Snow" Mid Atlantic. I have a question about the 2) options that ProSoft has for Ethernet/IP to BACnet/IP...
4,455
Hi, We have an application that has a device that goes through a reboot (appears un-graceful) What then happens is the MVI module appears to hang...
80
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
114
Hello. I am trying to use a Prosoft AN-X4 to improve the communications for a new panelview plus 7. This is going from a SLC-500 through DH+ to a...
299
