BACnet ProSoft Module
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello all. I have a project that requires the use of BACnet over RS485. I am looking for something low-cost that I can connect that will talk BACnet over a ProSoft Module I purchased and installed in my CLX rack/bench unit. Any ideas would be awesome. Thank you
Hello ceilingwalker;
Have you need of something more than a PC simulator software for Bacnet?
There are some free-doenload packages on the web. For our first Bacnet In our first Bacnet project we used SCADA Engine, with good results.
Look for more selections under this link:
ttps://www.google.ca/search?ei=0kpqWpvAHYnNjwS88aaIAw&q=bacnet+virtual+device&oq=bacnet+simulator+free&gs_l=psy-ab.1.0.0i71k1l4.0.0.0.22942.0.0.0.0.0.0.0.0..0.0....0...1c..64.psy-ab..0.0.0....0.80WdBDC1VmA
Hope this helps,
Daniel Chartier
Good Morning, Has anyone used the Ethernet/ip to Bacnet IP Gateway? Do both Ethernet/IP and Bacnet/IP exist on the same LAN? Thank you, Paul
969
Good Morning from the "Waist Deep in Snow" Mid Atlantic. I have a question about the 2) options that ProSoft has for Ethernet/IP to BACnet/IP...
4,455
Hi all, I have a customer who wishes to to display some of the information from their refrigeration plant (CompactLogix PLC on Ethernet/IP) on...
1,524
Anyone have success using Ignition 8 and the BACNet driver? We are going to try and read data out of our Carrier Chiller. Carrier tech is...
588
I am trying to get data from a Chiller to an AB PLC or to my SCADA system. The protocol is BACNet/Ethernet, which is a layer2 protocol distinct...
1,057
