Protool error
cjd1965
Apr 2007
UK
1,659
Hi
I have the following error on compiling the Protool and am struggling to fix it. Anyone familiar with this?
E3026 The format string for a process value in the Alarm_S message 1610612739 is invalid in language 'English (United States)'.
Many thanks
I have to assume this Protool application is integrated in a STEP 7 project.
If this is the case, close Protool and all applications except Simatic Manager.
Make sure your STEP 7 project with your problematic Protool application is open.
Go to File -> Save As... in Simatic Manager
Give a new name to your project, and check the checkbox "With reorganization (slow)
Click OK
Open the new project you just created, and see if the problem still exists.
Hi SigmaDelta
Your correct, it is integrated into the s7 project. I renamed it and recompiled, same result. i tried changing the protool language to English UK and this was the same error except it said English UK instead of English US
I dont need to show S7 messages ..rack/slot faults etc
Hi
I read that article wasnt much use but it did point me in the direction of PDiag which I dont have.
In your experience would I need PDiag to look at this issue?
It also speaks about a menu PLC>Messages which doesnt appear in my Simatic Manager (I just get the offline version of the PLC messages dialog box)
Hi it is DB49 which is to do with the RSE feature
The message text is
Rack @6W%t#TC@, Slot @6W%t#TD@: @1W%t#ErrTextLib@ on channel @2W%1d@
One thing you could try is to regenerate the Report System Error from the hardware configuration again.
Highlight the CPU, go to Options -> Report System Error... and then click Generate.
Otherwise the problem is really only Protool related. Can you find in the Protool project something a category called "Project Texts"?
After installing engineering software Protool v6.0 sp3 on a new laptop with windows 7 64 bits , we have the following error when we try to open it...
3,050
Hi, I have Protools V6 SP3 when I open a file I get an error. ??? If I open it in winCC it wants to convert it. All I wanted to do was change some...
22
5,136
Morning all I have a problem....dont we all lol!!! I need to edit the screen graphics on an OP37, which is running Windows 95 and protool v5.01...
2,104
hi, when I make compilation of my project i protool V6.0, I get error code E1207 with text: Cannot open "C:\Document......\Pro.fud" file. Where...
1,827
Does anyone know where I can download the Simatic ProTool software? Thanks.
1,533
