Protool no integration in step7
Kataeb
Jan 2007
www.livelovelebanon.com
636
Hy, I have the following softwares:
Protool V6.0 SP2 , Simatic Manager V5.4
In the protool software, I cannot check the Protool integration in Step 7 because it is greyed out.
What should I do?
Hi Kataeb,
if i remember correctly there is a setting just in the software i think if you start the protool software its in the FILE menu and says Integrate with S7 or something very similar
Dear Jdf, in ProTool Setup, the integration box does not appear (only the upper one).
Dear RobImb, in file menu, the "Integrate with S7" is greyed out and i cannot check it.
The Simatic installed softwares are (is something missing?):
SIMATIC products
Name
Version
Release
Release number
AuthorsW
V2.5 + ServicePack 1
R2.5.1.8
V2.5.1.0
SIMATIC WinCC flexible Runtime
2005 + SP1
K1.1.1.0_1.34.0.5
K1.1.1.0
Automation License Manager
V3.0 + HF3
K03.00.00.03_01.01.00.01
K03.00.00.03
PC Adapter USB
V2.0
02.00.00.00_01.08.00.01
V2.0.0.0
SIMATIC ProAgent CS
V6.0 + ServicePack 2
V6.0
K6.0.2.0
SIMATIC ProAgent/PC RT
V6.0
K6.0.2.0
SIMATIC ProTool
V6.0
V6.0
V6.0.0.0
SIMATIC ProTool/Pro RT
V6.0
K6.0.2.0
STEP 7
V5.4 + SP2
K5.4.2.0_16.6.0.1
K5.4.2.0
SIMATIC WinCC flexible Advanced
2005 SP1
K1.1.1.0_1.34.0.5
K1.1.1.0
SIMATIC WinCC flexible ProAgent
2005 SP1
K1.1.1.0_1.32.0.1
K1.1.1.0
There is an option when you install the program that lets you select the Integration.
When I installed Step 7 and Protool on my new laptop, I did not select this option and it would not let me integrate the two programs. I had to uninstall Protool and reinstall it and make sure the select the Integration option during installation.
I had the same problem and solved by reinstalling Protool. when installing you must check Protool integration which is unchecked by default. The same solution as posted Tharon.
Also there may be problem with WinCC Flexible integration. You may try delesect Flexible integration and then reinstal Protool with integration checked.
Later you may change integration Protool or WinCC Flexible. But only one of them may be integrated.
hi all; i created a project with an op with simatic manager, and i checked "file" -> "protool integration in step7" option. but when i try to add...
4,408
Hi, are there anyone out there that is using the "integration" option in Protool ? I can see that this option allows me to pick addresses in the...
5,435
Hello, I have an S7 project that has protools integrated. I somehow lost the symbols in protools so I cannot use them when i add an object and...
3,940
Hi Guys, I currently run Protool Integrated with Step 7, and have read on this forum that if Wincc Flex is installed on a pc with Protool that...
4,412
Questions about ProTool v6 SP1a Can anybogy answer me? My questions are 1st-ProTool is in integrated mode with Step7, but when I try set checkbox...
3,855
