Protool RT File
STL???
Sep 2005
UK
879
I'm currently looking at a preinstalled S7300 system with a siemens industrial PC attached via profibus. The manufacturer has provided the S7 project and operating disks for the PC.
Whilst looking at the project i checked out the TDOP folder which contains 2 files: PRO.FUD & PRO.TFY, i dont have any experience with runtime applications and my question is are these just compiled runtime files which are uneditable (like Prosave type) or are they source files ?
I have tried to open them unsuccessfully with Protool Pro v6.0 SP3
What am i missing here?
Thank you for any light you can shed on this
STL
I'm just running on a normal PC and I don't have the *.FUD files, so that may be something to do with it being an Industrial PC.
With the forewarning that I use ProTool Pro, which may have minor differences to simple ProTool, the main files are PRO__0*.PDB which is the program file, editable in ProTool Pro and PRO__0*.fwd which is the Run-time module. Apart from that there are various database files *. dbf, *.dbx, *.mdx and *.tfy + your *.tfy.
If you haven't got the *.PDB file, then you probably haven't got the source, unless it's been renamed and hidden somewhere. Try a search for PRO*.* - you might get lucky!
Hi RMA,
Thanks for the Runtime File breakdown, i searched the archives but couldn't place that information.
I opened up the *.FUD file in Ultraedit and in between all the (ÿÿÿÿÿÿÿ &  ÿÿÿÿ B ÿÿ  ÿÿ ÿ  ÿÿÿÿÿÿÿÿËT ÿÿÿÿ)
i came across this text:
Basic screen OP17
Events Alarms Screens Record
³ ³ ³ ³
³ StatVAR ³ForceVAR ³ System Password
³ ³ ³ ³ ³ ³ ³ ³ @
Password processing
So i'm at a loss! there certainly isnt no OP17 on the Cell
I have been on there website and looking through there press releases i found they now offer there own runtime enviroment - so the next thing to find out is whether its a VB C++ etc Homegrown creation or a solution using siemens hmi software.
I'd like to try and establish first what the system is before interrogating the physical console. we must have some sort of backup solution for this even if its just an image of the C Drive!
Thanks again
STL
HI All I am looking for a way to convert a protool project to win cc I have win cc 2008 SP3 and also newer but from reading I need 2008 SP2 or...
2,766
What is *.pdz file? Please correct me if Iam wrong From this image Configuration file is the *.pdb file Configuration backup file is the...
1,364
Hi, I have Protools V6 SP3 when I open a file I get an error. ??? If I open it in winCC it wants to convert it. All I wanted to do was change some...
22
5,155
Hi to everybody. I just want to know on how I can make an archive file that will be automatically generated daily. It will be a great help if the...
4,301
Hi all When i try to run Protool/Pro Rt version 5.2 sp 1, I get a message that i need to load a configuration (*.fwd) file.Where would I find such...
2,476
