ProWORX 32
blawrenz
Jul 2006
Kansas City
22
I am using ProWORX 32 version 2.0 for a project that I am working on. When I go to print my networks out from the report generator. I am unable to read the comments and addresses on the print-out. I have been able to get around this by right-clicking on the current network displayed and just printing individual networks but I have not been able to figure out how or if the font size can be changed on the comments and addresses. I have even tried exporting to a PDF and others with no success. Does anyone have any suggestions??
Thanks in advance.
Brad
Brad,
This may not be your issue, but check this thread for info on Proworx32 ver 2.0 reporting problems.It may get you going.
By the way, how does the report look in the preview screen?
Brian.
Brian,
I checked out that thread and tried the things that had been posted and was unable to get what I wanted. I am having the opposite problem that you had, the text is so small that you can't read it without a magnifying glass. So instead of changing from Large to Normal, I changed mine from Normal to Large and it basically looked about the same.
As far as how that it looks on the preview screen, again it is very small you can zoom in on it and read it. It also kind of looks like it is stretched a little bit, the coils look kind of oblong. I will keep playing with it maybe I will stumble upon a solution.
Thanks for the help!!
Brad
I have a zip file of a program that I'm told was created in Proworx NxT. Would the comments be stored in it if I could find the software or...
576
When making changes, I was taught to go to Combined > Make Change > go to Offline > will prompt to save > Save > Exit out of program > will prompt...
625
Would like to ask .. if anyone here know about creating own library or function block on ProWORX NxT ? I have a backup of ProWORX NxT project...
1,061
Hi I have a modicon 984 with proworx 32 that is scaling an analog input, and I need to adjust the scaling. I have new analog input values and %...
1,735
Hello everyone! I need help getting the installer for Proworx 32, I have to backup a 140 CPU 434 12A but I cannot find it anywhere on the...
2,565
