Proximity Switch, ML1200
SirCharles1
Jun 2013
Hamilton, Ontario
22
Good day my fellow humans. I am glad we are all trying to help one another. I have some proximity sensors/switches, they are made by PHD and the part number is JC1SDP-K. They have three wires, black, blue and brown. I would like to know how these are to be connected to a MicroLogix 1200 PLC, part number is 1762-L40BWA. See my pictures. Thank you very much.
Ah yes the new PHD JC1 switch. We discovered real quick that you have to turn the screw counter-clockwise to tighten it in the slot. So basically you loosen it to tighten it... throws Bubba for a loop.
Connect brown to 24v+
Connect blue to 24v- (common)
Connect black to the PLC input you want to use.
Since this is a PNP (sourcing) switch, you'll also have to connect the common terminal of the I/O group to 24v- in order to make a complete circuit. For example, if you use IN0, connect COM0 to 24v-.
As long as you aren't using more than a handful of sensors, you can use the onboard 24vdc supply.
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
296
Dear My Friend I needs help to measuring motor speed by using Proximity switch and Serrated disc with 14 convexity Thats mean I will have 1...
2,441
I have a Direct Logic 05 series D0-05DR-D PLC. I need it to sound an alarm to the machine operator if a rotating shaft stalls. This is my first...
18
7,581
I am working on a plc system that works with conveyor belt and nematic press as outputs and 2 reed switches on the air cylinder and a proximity...
3,700
I would like a NO VOLTAGE, DRY CONTACT proximity switch. Give me one now! Or please direct me to a website where I may purchase one or make...
5,182
