Measuring Motor speed By Proximity switch
alijuda
Jan 2013
Iraq
62
Dear My Friend
I needs help to measuring motor speed by using Proximity switch and Serrated disc with 14 convexity
Thats mean I will have 1 pulse in each 0.002 Second
Is possible to use I:0/0 in ML1400 1766-L32BXB to made CTU and take the C5:0.acc in each 5 sec and Divided the C5:0.acc / 14 to find RPM then MUL the result by 12 to find RPM in 1 minut
waiting your help and advice
Best Regards
Ali
The MicroLogix 1400 has onboard high-speed counter circuitry that allows it to count very fast pulses that could otherwise not be handled by ordinary ladder logic.
The very fast 500 Hz+ frequency of these pulses means that the High Speed Counter features will definitely need to be used.
An excellent example of using the High Speed Counter (HSC) feature in conjunction with the Selectable Timed Interrupt (STI) is described in RA Knowledgebase Article ID # 19445, Using STI To Calculate High Speed Counter Rate Value on MicroLogix Controllers. A TechConnect support contract is required to view that document.
I am working on an application where I need to make sure the case of a dc motor has not become shorted to the armature windings. Normally the case...
4,671
I am in need of meauring the inrush current of a 3 ph motor. I have a 2 channel scope and am looking for suggestions for current probes/meters...
30
10,872
Hi everyone, I don't know much of PLCs but it happened that i need to connect Leuze AMS358i Ethernet laser measurement to Productivity 1000...
1,064
Hello everyone! Firstly I'd like to say that I'm new to this forum and also new to PLC programming world altogether, that said I really would...
27
4,851
I am looking for a way to determine level in a silo. The material is called Perilite which has a very light density. Bulk density could be...
2,752
