ndzied1
Let me try this again with the plots rotated.
The clamp on current probe puts out 1mV/Amp. Each plot shows the starting of the same 125 HP / 460VAC / 60Hz Motor. The motor is a double shaft with one shaft driving two hydraulic pumps and the other shaft driving a single hydraulic pump. All pumps are unloaded during startup.
The first plot starts on a down cycle and peaks around 1500A at the bottom. The second plot starts on a an up cycle and peaks around 2200A. There were no changes in the system between startups. I guess there can be some variability in startup current?...
The RMS reading on the right is a function available in the scope and is the RMS value for the entire plot. I thought it might be a good way to compare plots from different motors. Does this seem like the best way to compare startup currents or should I just look at the first peak?
There is a function in the scope called CycleRMS which is supposed to measure the RMS of the first cycle but it was giving me an error. This might be because of the 50msec pre-trigger in the plot. I will check that next week.
In both plots, the current settles down in the first 350 msec after starting.
Next step is to put together some of the 25HP units in question and start them up with different motors and see what the plots look like.
