proximity switches telemechanique XS4P30MA230
jamilhisham
Aug 2010
earth
I have a problem with this sensor. How do I know if they still work or is damaged. led does not light up when he moved to the proper place. Please help me....
have only 2 wire... i'm not sure npn or pnp?... i'm background in electrical power dont know advance in plc... please help i need to replace it if unit damage. Thanks
If that's the case: Hook it up to a 240V test lead. Put a 60W light bulb on the other end of the sensor. That'll give it a good work out. Wave a piece of Ferrous steel in front of it.
There will be a direct replacement available. You a have a common size and spec'd sensor.
Lightbulb should be 240v and not 120v.
Sorry, couldn't resist. Here we only have 120v, there you are on 240v. It was a funny thought to think of the bulb burning very bright for just a second. :)
On my last trip to Brazil the hotel receptacles would accept either a European 2-pin plug or a US style blade plug. It was discreetly labelled 240v. My laptop and phone charger and electric razor were all dual voltage with US style blade plugs.
However a colleague plugged his 120vac electric razor into a receptacle. It went poof and that was that, no shave for you!
Hello My PLC experts, You guys have no idea, How comfortable I feel because of this forum! Currently, I am working as a Junior PLC and robotics...
30
5,190
Settle an argument, Application hoist lifting a heavy load + 300-500kgs If the hoist over travels substantial damage could be done, not...
3,175
Hello all, I am not terribly experienced with all this stuff so forgive me if I am asking a silly question. Hopefully there is some simple answer...
1,495
I found a Turck proximity switch for my trainer, I just want to make sure its gonna work on my system. Such a device is a input right! And if my...
2,644
I've got a question about the Banking Screw accessory for Balluff Switches. I have a 12 MM Banking Screw (BALLUFF BESA-12-50-12-BANKING-SCREW)...
3,277
