Ps416 cp300
karabarera
Oct 2021
Edinet
HI.
If possible, please help us to sort out the PLC PS416 CP300 .
Install the OS via sucosoft, everything is ok.
Then we install the pcd file from the flash drive, which was copied from the working PLC.
Program status shows that the pcd file is installed on the PLC.
Status (-)
Startup (activ)
When you click on cold start, it gives an error: "OS40ERROR(80ea) Lenght of card parameters not corecct".
Can you tell me if we are copying incorrectly to flash or what is the problem?.Thanks
https://a.radikal.ru/a34/2112/8d/a0fc6105246a.jpg
https://c.radikal.ru/c43/2112/7c/0346b63d96c7.jpg
https://radikal.ru/lfp/b.radikal.ru/b11/2112/b6/2a01c0e02fb3.jpg/htm
ПРИВЕТ.
Если есть возможность, пожалуйста, помогите разобраться с ПЛК PS416 CP300.
Установили ОС через sucosoft s40, все ок.
Затем устанавливаем с флешки файл pcd, скопированный с работающего PLC.
Статус программы показывает, что файл pcd установлен на ПЛК.
Статус (-)
Запуск (актив)
При нажатии на холодный запуск выдает ошибку OS40 ERROR(80ea) Lenght of card parameters not corecct.
Можете ли вы сказать мне, если мы неправильно копируем на флешку или в чем проблема? .Спасибо
Good afternoon ladies and gents. One of my potential customers currently has a Moeller PS416-CPU-300 PLC and we're looking at upgrading to a...
1,371
Hi, I have to upgrade the Moeller PS416 program to a newer PLC. I have the old program and I would like to open it but I don't have any idea how...
2,072
I have a problem, I can not read the contents of Moeller PS416 PLC CPU400. Connects to the PLC and gives mii option to record the program...
2,044
Hi, I was called out to a customer to help diagnose a problem with on of their machines. It has a Moeller PS416 CPu200 plc. The following LED's...
2,729
Hi all, Firstly, I know very little about PLC programming; And I would like to find someone who is able to undertake and complete a conversion...
3,118
