PS416 program
maciej_sz
Jan 2015
Poznan
Hi, I have to upgrade the Moeller PS416 program to a newer PLC. I have the old program and I would like to open it but I don't have any idea how to do it.
I tried to use Sucosoft but it failed. Do you have any advices?
Zip and post the program, maybe someone can convert it to a .pdf file for you.
I succeeded to open the program using the POU Editor in Sucosoft. But I have got another problem. The original program was created in S30. After conversion I get the code in IL language but the converter has problems with conversion of the logic statements. I get the SYS instrucion and it is described in help as follows: "The PP operands and the SYS commands are transferred to the S 40 source program without any changes. They create a syntax error when compiled. In this case, adapt your program logic accordingly."
My question is: how can I get the original logic statements instead of SYS instructions?
HI. If possible, please help us to sort out the PLC PS416 CP300 . Install the OS via sucosoft, everything is ok. Then we install the pcd file...
1,231
Good afternoon ladies and gents. One of my potential customers currently has a Moeller PS416-CPU-300 PLC and we're looking at upgrading to a...
1,374
I have a problem, I can not read the contents of Moeller PS416 PLC CPU400. Connects to the PLC and gives mii option to record the program...
2,053
Hi, I was called out to a customer to help diagnose a problem with on of their machines. It has a Moeller PS416 CPu200 plc. The following LED's...
2,732
Hi all, Firstly, I know very little about PLC programming; And I would like to find someone who is able to undertake and complete a conversion...
3,120
