PSA: Don't update PF7xx drives to 11.001+
einnh
Mar 2014
New England
275
Those of you using PowerFlex drives to operate spindle heads for routing ops,etc. Don't update your PowerFlex drives plast firmware 11.001 as it limits the output to 590Hz (per new US government regulations).
Thanks for the heads up.
Seems like a poor and broad way to try to control uranium enrichment centrifuges. I'm sure nobody could possibly figure a way around that and meanwhile the rest of us with high speed applications are out of luck. Unbelievable really.
You mean a Government regulation is screwing everyone other than who it is supposed to stop?? NOOOOOOOO:beerchug:
Next you will have to apply for a special permit just to buy a drive that will operate above that limit. I can see it now: Department of High Speed Drives. Cant wait to pay for that.
Rant Over :)
You already can apply for a special permit to operate a drive above 590Hz, through DHS or DOD, I can't remember which now. They will investigate you and your business and if it is for domestic use and you are not exporting anything, you can likely get a variance. This is not new, the requirement has been in place since January 15th. But if you were exporting and did not have a drive already limited to 590Hz, you had to get the permit to export. Now that the limit is in place in firmware, the only people required to get the variance are those not exporting and needing the higher frequency. That's far far fewer people.
This does not only apply to PowerFlex, ALL drives must comply and most other countries have complied already. The US was just the last country to enact this, and Rockwell is one of the few remaining US drive mfrs., so it appears to be something new to us.
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
310
I know there are a lot of regulars here who work with hydraulics. A reminder to be careful. Friday Otis was tightening a slightly loose fitting...
2,383
Why I never jump into the latest version........
3,187
I have been reading everything I can find on the P_LLS the last 2 days but I am still having trouble understanding how the P_LLS swaps beyond 2...
600
