Pseudo Redundant ControlLogix System ???
pedroascencio
Sep 2007
Concepcion
Hello Everyone,
I need a simple solution for my customer who doesn't want ControlNet redundant (CNBR) modules, he want only CNB modules with 2 "real" controlnet networks separate between 1 Local chasis and 1 remote chassis.
I don't have experience about this, so If someone can help me, I would be very grateful.
These are the componets of my pseudo redundant solution:
1 chassis Local and 1 chassis Remote.
In the Local chassis I have only one processor and 2 CNB modules (not redundant, just CNB)
In the Remote chasis I have 2 CNB modules and I/O digitals modules that command differents motors and read its status.
Is possible to connect each pair of CNB (Local-Remote) by separate?, So that, by GSV instruction the processor to decide through which network write/read remote I/Os???
I don't know if I am going to have some problems synchronizing both networks separately by RSNetworx, because the CPU would be addressing the same Remote chassis by 2 diferents networks.!!!!!
thanks for your help.!!
I have an application where I am converting a binary 2 digit number (00-99) to BCD to display on a 7 segment display. Unfortunately I don't have...
4,265
I wish to develop 2 "standard" plc programs and matching HMI applications. One program is intended to ultimately run on a CompactLogix PLC and...
2,969
Hi, for an assignment on school I need to make a PSEUDO-random generator coded in STL/SCL wich needs to make random numbers from 50-999 and from...
15,702
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
128
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
96
