PT100 step 7 strang analog value
Dear engineers, the problem is solved...
The M12plug being used to connect the sensor with the analog card had an LED light which was using some mili amperes, which was read by the analog card... o_O
Cable replaced, now has M12 plug without LED, all readings are correct. Thanks all for the input!
Shooter, thanks for the offer. I checked the Oscat library, it looks very useful.
Good catch! The M12 plugs with LEDs only works with digital sensors.
So I'll guess we'll put this problem down as "not wired correctly".
Have you seen a PT100 sensor reading going slowly up, even after heating power turned off ?! and it keeps rising for several minutes ... It looks...
4,505
Im having a 3wire pt100 connected to a temperature transmiter. Im reading the current in the loop and I have 22mA, so is overrange. What could...
1,693
Hi. Almost every time when working with PT100 probes the customers ask me "have the probes been calibrated?" The reason for the customers to ask...
18
5,084
Hello, can someone help me with scaling PT100 RTD useing Schnider m211 PLC? I can see the analoog value on the controller but once the temperature...
4,314
Hi all, Not sure how to call this, but my client wants a module that offers a dry contact, if one of three pump/motor bearing temperatures...
2,994
