pulse I/O board
edman
May 2007
ohio
I was wondering if it possible to send pulses to a vision sensor camera, banner P4ER, using a pulse I/O board to trigger the camera. I can get the camera to trigger using the transistor outputs on the OD212 output module, but the frequency of the pulses is too low(1KHz). Any help or advice would be greatly appreciated. The pulse I/O board works well for controlling my rotary actuator, but I am starting to believe that is the only thing the output pulses can control.
Thanks,
-Erik
Erik,
I am not familiar with the Banner vision sensor, but at 1khz that is one pulse every millisecond. I seriously doubt the vision sensor can process that rapidly, let alone faster.
Just my two cents.
hi
Hope u r using a Vision COntroller through which u trigger the shots.
The Pulse input depends on the input pulse frequency of the controller. The trigger frequency[pulse input] should not exceed the limit. The pulse input frequency depends on the Scan rate[millisec]of camera & its processor.
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
187
Hi All, I'd like to know can we use DTR instruction to get a week pulse ? Could anyone please help me to understand that one ? I've managed to...
192
Hello, I am struggling to figure out some logic. I have an analog pressure sensor coming into the PLC and would like to have multiple timing...
162
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
124
I am monitoring two BMXDDO3202K digital outputs for their behaviour, they are each for opening and closing, and so the on time affects how far the...
293
