Peter-
What you are saying about the PLC is quite true. There is a lot of work in pre-design to get the motions required for the desired wave. What goes in, is not necessarily what comes out. Especially in an open system. I believe the same is true with hydraulics.
Then, there's your video on pneumatic motion control. That is truly an accomplishment. Very impressive. Your motion controller is a serious computer. And, I suspect, the valves and rod-less actuator are of a high quality. So much to compensate for: irregular friction, fluctuations in available pressure to the valves, inertia of the moving carriage, resonance .. and so on. Nicely done.
You have made your point. I drool on my keyboard watching that video.
Then again, you must appreciate that the water surface is quite forgiving. Generally all that matters is the height and frequency (or Period, marine engineers say) of the regular wave, when you are testing in only regular waves. Data such at wave height, wave period and any other important information as a function of time, about the object exposed to this ocean environment, is recorded. And, charts are generated showing each value or interest as a function of a range of periods. Motion data (pitch, roll, heave, surge & sway) force data: moments and structural forces..displacement, velocity and acceleration forces are logged. When the Random Sea is run, then things get tricky. Spectrum analysis must be run for the waves where the model will be placed, and adjustments must be made to bring the spectral curve into alignment with the desired, theoretical distribution of ocean energy.
There are limits to what reasonably can be had from model testing in the scale of 1:200. (Ohmset likes to work in 1:1 to about 1:50
I was going to design a tank for an Arabian prince, that was building a science museum in Saudi Arabia … my partners and I didn't take the bait .. but, that's another story. I'm not really interested in that scale of a project. I want to find out if there is any interest by any US institution (educational or other) in a way to accurately model the ocean surface for scientific demonstration or study … at a fairly low cost. Bigger and better, would cost more … and for that, I suspect I could afford your motion controller …
Thanks again for your time and interest.
Regards, Michael
