Pump sequence using Delta PLC
sudanee
Mar 2009
Sudan
Hello
I need help to program pump sequence using Delta CPU 14ss2 (14SS211R)
The program in Auto mode will be
Cycle A - Pump 1 and Pump 2 Run.( Pump 3 on stand By)
Cycle B - Pump 2 and Pump 3 Run.( Pump 1 on stand By)
Cycle C - Pump 1 and Pump 3 Run.( Pump 2 on stand By)
Cycle A –again
Cycle will changed on Time 8 hours for each cycle
In any cycle if one of the Pumps fails or trip then the standby pump will come in Operation.
Thank you
What part of the program are you having trouble with?
I would set a counter that increments after 8 hours. The counter resets after it gets to 4. (Number of Cycles)
Depending on the count value do your logic.
Regards,
Garry
http://www.accautomation.ca
Hi everyone, I am a newbie and I have trouble in the control sequence. I have a system with 4 pumps. The required: Ex: Push a button to start in...
21
2,771
Hello there, I'm new to the PLC world, which I found pretty interesting but I'm having some difficulties getting things done for a project of...
2,075
so I have five running times on five pumps When these are started I want to know the start up sequence from lowest running time to highest Then...
1,580
i need to control six pump sets. initially 2 pump sets will run after two hours another two will run and later the third pair. 5 bar pressure...
26
13,638
I have 4 pumps. I need them to alternate (pump one, two, three, then four). I also need a way to increase number of pumps with demand. I also...
6,353
