pump sequencing zelio ladder diagram
Bujari
Oct 2017
Prishtina
I have a situation with four pumps which have to work 3 duty and 1 standby.
However the question is how I can make work to sequence them every 6 hours (1.2.3 on first six hours; 1.2.4 on second six hours; 1.3.4 on third six hours and 2.3.4 on fourth part of six hours)
You need to set up a simple timer circuit that will output every 6 hours. This output can then increase a counter to provide you different modes of operation.
You then reset the timer circuit to start timing towards the next cycle.
That should be enough to get you started, have a go and post what you've done if you run into problems.
I know it is a lot to ask but could you please state what version of ZelioSoft you are using as well as the exact model Zelio module you will be using?
Please also state that this is not a classroom homework assignment. It appears to be a standard classroom assignment and I don't like doing classroom assignments. As Jonnie R said " show us what you have so far".
If it will help you to understand what you might need for this program, here is a general outline of what I did. I used the pump not running, either 4, 3, 2, or 1, to determine the "Standby" (shut off condition), rather than trying to sort out all the possibilities to turn on the different groups. I used a self-resetting timer to increment a counter as Jonnie R said and the "V" instructions for comparing a value in the counter. Maybe this additional info will be enough to allow you to design the program you need.
Do you have to use ladder? Function block has got graftcet (or sfc) option that makes this easier.
I recently made a simple program which controls four pumps to maintain line pressure of a glycol system. Two pumps are running at any given time...
2,191
Hi Everybody I have three pumps to control in auto mode. Is it possible to do the sequencing of the three pump in hardwired without the use of a...
40
20,928
I am working on a PLC program to allow an operator to select the order (of 6 pumps) that they would like them to start in. For example I have an...
5,263
84
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
139
