pv 700+ and ML 1500 LRP Comms help
Adam303
Aug 2009
Chicago
587
Hi we bought a piece of used equipment that has a PV 700 + and a micrologix 1500 LRP communication via DF1 channel 1 (2711-NC13) The Pv's display went out and we had no backup of the application. I uploaded using FT ME and Downloaded to the new PV+ (2711P-T7C4D1) and still could not establish comms between the two. After going to the configuration screen under Terminal Settings>Network And Communications>RSLinx Enterprise Communications I selected DF1 driver then Edit Driver Station Number changed it from two to four and the comms wore established. I not quite sure what the station number represents. Everything was working till the next day the comms wore lost again and the station number on the DF1 was changed back to two, again I changed it to four and the comms established.
Can anyone help as to what the station number is? And why it changes back to two?
Hi Does anyone know where we can download firmware for a PanelView Plus 6 700 please? The versions on the Rockwell website start from 6.00 but...
4,413
i am having to replace an old hakko HMI with a PV+700 and the original cable was a 25pin male from the screen to 9pin female back to the 1500, i...
1,712
Hi all, i've got a bit of a problem establishing a connection between a PVP700 and ML1500. I have previoulsy done this on an identical machine...
1,896
I am trying to control the powerflex 700 with a 1769-of2 analog output card on the micrologix 1500 plc. I want to use the PID instruction and...
2,663
PanelView Plus 700 2711P-B7C4D1 Micrologix 1500 0764-LRP Ok, so the main problem is I cant get these two animals to communicate. I wrote a very...
10,034
