micrologix 1500 and powerflex 700 vfd
Programmer4
May 2009
Tennessee
29
I am trying to control the powerflex 700 with a 1769-of2 analog output card on the micrologix 1500 plc. I want to use the PID instruction and maintain the vfd speed reference based on an analog input signal to the drive at analog input 1. I have Pressure transducer that I am wanting to scale and keep the pressure maintained at 105psi. How can I do this and what parameter do I need to set in the vfd. 4-20mA signals.
87
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
107
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
921
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,210
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,431
