russrmartin
Hi guys. We had a PV on a DH+ network that we are going to replace with a PV+. THe PV is at node 5, and I was thinking that the new PV+ would just replace it as node 5. I set the target to be the SLC desired, which is node 1 on this network. However, the PV+ will not communicate with the SLC and Linx classic does not ever see the PV+ on the network. The total network has about 9 nodes sitting on a 1756-DHRIO module. The PV+ will have to communicate to the PLC over this network. I'm unsure of how to setup comms though. It almost looks like somehow I need to configure the PV+ to know that it is node 5. Has anyone done something like this? Thanks.
Russ
Russ
