PV300 DF1 to PV550 with RS232 and RIO
ema
Oct 2012
IL
I am trying to download a program onto the a PV550. The program was initially written for a PV300 with DF1 communications. The PV550 has RS232 and RIO. What do I need to change in order for the program to be uploaded. I keep getting an error that says that it is not compatible.
Welcome to the Forum!
The golden rule when dealing with PanelViews is to quote the complete model number when asking questions. There are just too many of them.
Please give us the complete model number for PV300 and PV550.
If possible, post your edited PV550 PB32 File so we can look at it. (Zip if first)
Stu....
I think you've identified the basic issue already; while the PanelView 550 does have an RS-232 port, that port can be used for ASCII printing or for upload/download.
The RS-232 port on the PanelView 550 can't be used for runtime communications.
You would have to do significant revision to the project to get it to run on the PanelView 550, not to mention the changes you'd have to do to whatever controller you have in order to implement a RIO scanner.
The simplest thing to do is get another PanelView 300 terminal, or a PanelView 550 with a DF1 serial port (2711-K5A16, 2711-T5A16L1, or 2711-B5A16).
Thanks for the Response.
I will get the proper PV550. That will be the simplest fix.
Thanks!
I am trying to get a PV300 micro to read tags from a CompactLogix L32E via DF1 protocol. All my tags are rejected with a 9409 error - "Address...
3,364
I am trying to link to a PV300 (not micro) that is directly connected to the Ch0 (DF1) port of a SLC 5/03 (OS302). My computer is connected to a...
5,645
Hello all, I've utilized many threads on this site and gleaned much information throughout the years. Now the time has come for me to finally...
1,784
Hey, I'm trying to upgrading some old PV300 Micro screens. I have communication on RSLinx but I can't get it to where I can get to the program...
2,907
The question is at the bottom ... 1st the buildup. I would like to change a prgm that is in a PV300 Micro which is configured by Allen Bradley...
27
8,066
