Pv550 - Aic - Micrologix 1500
mbradford
Aug 2006
Michigan
Hi everyone, this is my first time posting but not my first time having communication problems with AB equipment. I am trying to connect a Micrologix 1500 controller to a PV550 panel (PV 2711-B5A2) via a 1747 AIC. Using RSlinx RS-232 DF1 devices driver, I can see the controller and comunicate with it fine. The Panelview however does not show up on the network and the display on the PV indicates "Data errors on the link". Does anyone know what this means and how to solve it? Thanks in advance.
Your PanelView has DH485 protocol. You will need to change ML1500 channel to this protocol. SEE pic below
Hello everyone, I'm trying to get this setup online so it can be programmed remotely. Current configuration (works fine) is: Panelview 550...
3,980
I have a panelview 550(2711 k5a5) connected with a 2711-NC21 cable to a 1761-NET-AIC, ML1500 LRP connected with a 1761-cbl-hm02 cable to a...
3,585
Is there a way to add a stop to the attached program? I want to stop it after the first rinse so the operator would have to push a button for it...
1,226
I'm trying to connect a PV550 (2711-T5A2L) to a 1761-NET-AIC using a 1747-C11 cable (w/RJ45 removed) and the Phoenix connector. Can someone tell...
2,668
We have an old machine that has been mothballed since early 2018 and management are looking at more work for it in 2022. The system runs on an SLC...
2,877
