Hello All,
I installed a system with a PV550 and a ML1500 with two 1761-NET-AIC's a couple of years ago. The costumer want to do some changes to the HMI, so I am trying to modifye the HMI in the office using an old PV550 (2711-B5A5 FRN 1.07) and a ML1200. I did it 2 years ago but now I can't.
I am conecting my laptop to one of the NET-AIC's via an 1747-UIC and cable 1761-CBL-PM02. and the micrologix to the other NET-AIC with cable 1761-CBL-HM02. This works fine, I can see the Micrologix 1200 in RSLinx.
To connect to the PV550 I am using cable 1747-CP3 with a NULL-Modem adaptor.
If I connect the PV550 to the NET-AIC where the 1747-UIC(laptop) is connected to I can see the PV550 in RSLinx but not the ML1200, and the same time the PV550 shows the error message "Require network node(s).
If I connect the PV550 to the NET-AIC where the Micrologix 1200 is connected to I can't see either the PV550 or Micrologix 1200 in RSLinx but I do not get the "Node" error message on the PV550.
Instead of using cable 1747-CP3 with a Null-Modem adapter I also tryed to use cable 2706-NC13 (straight trugh cable) as I think I did 2 years ago, but that doesn't work either.
Any Suggestions
Regards
gert
Any Suggestions
Regards
gert
