sabreflier
I bet someone has already posted the answer to this , but I haven't found it yet:
I'm helping out a friend who has a PV 550 (2711-K5A2) connected to a SLC5/03 (1747-L531). They do not have the program for either the PLC or PV. I was asked to try and download the programs in case one dies (and they both look close to it).
The DH-485 port on the PV is connected to the top port (port 1?) of the PLC. There is another unused port on the PV which looks like an RJ-45 socket.
The bottom port on the PLC (port 0) is a RS-232 port. I have tried to connect to that port using a null modem cable and DF1 driver is RSLinx, but it will not work - even on autodetect. I have always used DF1 to connect to PV's but this unit does not have a DB9 connector.
This is a continuous process that only shuts down a couple times a year, so whatever I do can't disrupt the PLC. Any suggestions?
