RIO PV550 to 1747 SN B & SLC 5/04 OS401 B
Edwinsky
Apr 2005
Pasig CIty
34
I hope somebody can guide me on right direction. I’m trying to setup for the first time a RIO PV550, 1747 SN B and SLC 5/04 OS401 B. For almost three weeks of reading manuals, searching on the web and testing my programs still nothing happens on my Block Transfer so please help me. I don’t have the actual ladder for some of the data words I used on the BTR & BTW data but I created the data table for the BTR & BTW to read and write, I just wanted first to see 00’s on my PV or toggling bit 0 to 1 on plc ( I hope this is possible). I am trying to use the Bidirectional Alternating Repeating Block Transfer for earlier processor similar to sample program on 1747 SN manual, but during testing the program I observed that it always got an error of -9 (Block Transfer Timeout).
What really confused me are the setup of BT’s control words and mapping of M0 / M1. I’ve no success in searching the web for manuals that can explain this well. I try to put some values on slot, group & rack on control words but got the same error.
When I try to use the assigned I/O words on G file as my tag for some PV switches and made test programs on plc it works, so I know part of my setup is right.
Here are my test programs for you to examine quickly. Many thanks in advance.
Regards,
Edwin
Hi, I am trying to download a program onto the a PV550. The program was initially written for a PV300 with DF1 communications. The PV550 has...
2,322
Currently, I am working in a migration of a PV550 RIO to PVP600 RIO (adapter RIO module 2711-RN1). In the RIO network those are a SLC 500 5/04...
3,579
hello, I have a problem with my AN-X2-AB-DHRIO Prosoft module, I can't connect with the module because I lost a microSD card that has firmware and...
388
We have a remove PLC rack that is being used to collect data from older equipment via a 1756-DHRIO module. This module occasionally faults out...
417
Does anyone have information or documentation regarding the protocol used in Rockwell's Remote IO, and how the physical layer of the network...
937
