PV550 Communications
jthornton
Jul 2002
Poplar Bluff, MO
295
I have a PV550 2711-T5A2L1 with DH485. I have the 1747-UIC on my Windows XP laptop. My sketchy notes say to use RS-232 DF1 Driver, 1770-KF3/1747-KE Device, CRC, 1 Stop Bit, Full Duplex, Do Not Auto Configure. However I failed to write down what cable I used. I've looked through my cable suitcase but don't see an obvious cable to use. Anyone have a clue what I need. I must have it as I've done this in the past. I need to download a program from one PV550 and upload to another one for a backup.
I also have a small rack with a power supply and a SLC 5/03 processor...
I have a 1747-C10 SER B and a cross over Ethernet cable.
JT
So I need to make a RJ45 straight through cable with pins 3 and 6 not connected to connect from the 1747-UIC to the PV550?
Is the 1747-C10 the cable to connect the PV550 to the SLC5/03?
JT
Argg this is so frustrating... I made a pass though cable with pins 3 and 6 missing and used a Cat6 connector so I could make sure I had the wires in the right spot. I could not see the PV in RSLinx.
Finally got to the setup screen of the PV550 and Node: 2, and Baud: 19200. There is an error "Required network node(s) not found" on the communication setup page of the PV550.
I followed KB G75736127 DF1 passthrou to DH485 PV but still can not see the PV in RSLinx. S34/0 and S34/5 are 1 and S34/6 is 0.
JT
Is the firmware OS302? Where do I see what firmware supports pass through?
JT
The second pdf I posted above.
But if the PV is not talking to the SLC passthru is not going to work.
Double check cables, node addresses and baud rates.
I don't get it... I went to the industrial park plugged into 3 different PV550's copied programs and came home and plugged into my PV550 and bam it is there... must have been doing something stupid in my frustration lol.
Mickey thanks for all the help.
JT
Hello everyone! I've been loaned a Micrologix 1200 (1762-L24BWAR) and Panelview 550 Keypad model (2711-B5A16) with the goal of using my free time...
4,675
I am not sure if this is even possible but.. I have a PV550 (DH+) that seams to have a defective main board and a new PV550 (RIO) in stock. Is it...
2,069
Is there a way to add a stop to the attached program? I want to stop it after the first rinse so the operator would have to push a button for it...
1,226
I'm trying to connect a PV550 (2711-T5A2L) to a 1761-NET-AIC using a 1747-C11 cable (w/RJ45 removed) and the Phoenix connector. Can someone tell...
2,668
We have an old machine that has been mothballed since early 2018 and management are looking at more work for it in 2022. The system runs on an SLC...
2,877
